Walls outlines in section are showing light grey instead of thick black
Igor Moraes
I can't find how to make the outlines appear black. as in a section mode.
I'd appreciate any help
Att,
Igor
The walls in section will appear (by default) exactly the same as they do in plan.
In other words, as you have set them up in the wall composites.
However, you can override the cut and uncut pen colours.
This can be don on a wall by wall basis in the wall settings.
Or you can go into the section settings and there will be the same options, but it will affect all elements in that section.
Ian_Dorn
Hi Igor,
It's hard to say for sure what is going on in your drawing since we don't see the full screen, but it could be a number of things.
Things to check:
1. Renovation Status.  If the wall is designated as existing and you are in a new construction or planned status renovation filter, the existing graphic override could be causing this.
2. Graphic override.  Not to be confused with the graphic override of the renovation status.  A graphic override may be changing the color of the line type of the cut lines.
3.  There could be a graphic override in the wall settings itself.  (this is the only setting I can see in your image and it appears not to be the problem.)
Good luck.. and I hope this helps.
