I probably knew the answer to this at one point, but baffling me now.
I have interior walls that are trimmed by a roof above. But the cut is apparently occurring at the top/exterior plane of the roof, rather than the bottom interior side of the roof. Thus, I am seeing the "footprint" of the walls on the top of the roof where I should be seeing uninterrupted roof finish material.
I get the desired result when using conventional SEO operations, but the "trim elements to roof/shell" is easier to use, and I'm accustomed to getting the desired result with that command.
What I am overlooking?
Thanks.
Mac Studio, 32gb ram, ArchiCAD v26 (Apple Silicon) MacOS 13
