Walls won't auto heal...
Can someone please tell me why my walls will not auto-heal in AC10 when I draw a continous wall with right angles.. I dont know if i accidently turned off something because this has not happened before. Even when I try to intersect two walls, the command does not work. Any advice in this matter will be appreciated.
Thanks in advance!
Window > Toolbars > On-Screen View Options. Check if "Clean Wall Beam Intersections" option is activated (first option - see attached image).
Cheers.
Adrian Tudoreanu
Thanks! After more trial and error I did get it to work, but thanks for reassuring me that what I did was correct.
Once again thanks!
