jarkwiat
Weird selection
Hello, does anyone know why this is happening? The file opens with basic AC29 settings, but others with these settings don't have this!
ArchiCAD 29 POL FULL iMac 20,1 Intel Core i5 3,1 GHz 24GB RAM AMD Radeon Pro 5300 4 GB
1 Solution
marcoariveross
Hi
That happens because you're working too far from Archicad's origin. You can fix it by moving your project as close as possible to Archicad's zero reference point. This happens in all 3D software. Sometimes people confuse georeferencing with moving too far.
That should solve it.
BIM Manager Pavimaq
Lima-Perú
Archicad 29-Windows 11-64Gb RAM
Go to post
2 Replies 2
marcoariveross
Hi
BIM Manager Pavimaq
Lima-Perú
jarkwiat
Yes, that solved the problem, thank you, best regards!
