2005-06-30 07:23 AM
2005-06-30 08:50 AM
2005-07-01 12:03 AM
2005-07-01 12:19 AM
2005-07-01 12:27 AM
Link wrote:What you say is true, but assumes the slabs extend to the exterior face. Some firms prefer to stop the slabs at interior faces, or even inside the walls and SEO the joint. Of course in either case, there is always the offset tool.
It's easier for magic wanding onto slabs if the reference line is on or referenced from the outside, but as Matthew said it depends on your goal.
Link.
2005-07-01 12:38 AM
2005-07-01 01:27 AM
2005-07-01 01:33 AM
2005-07-01 01:55 AM
Matthew wrote:Also assumes you draw your slab before you draw your wall.Link wrote:What you say is true, but assumes the slabs extend to the exterior face. Some firms prefer to stop the slabs at interior faces, or even inside the walls and SEO the joint. Of course in either case, there is always the offset tool.
Link.
2005-07-01 02:13 AM
For many cases it doesn't matter, but the joint pictured here will only clean up if the ref lines are inside.This is what Matthew was referring to right? This is where I find gyp and ply skins are better left out of composites, as they create as many problems as they solve, if not more. Conversely, the same problem would arise with external walls if your reference line is on the outside.
In 3D it becomes moot. I really, strongly, dislike that line.Me too James - especially since the materials are the same.
Also assumes you draw your slab before you draw your wall.Which is quite often the case in a multi story building, but I will point out, again, that all of this depends on how you model and what your final goals are.
