Where is Extend Pallets in AC 10?
Hi AC 9 we had a dialog box with options to extend the pallets, where is it in AC10?
Thanks,
Joseph
9 REPLIES 9
Link
Right click on it!
Link.
Link wrote:
Right click on it!
Link.
Thanks,
Also where is "Intersect Walls", I am missing this one badly (should I put it in another post?)
Thanks Again,
Joseph
Link
In the ArchiCAD 10 Standard profile it is at Edit > Reshape > Intersect.
It's not just for walls BTW, also for lines & arcs.
Link.
Link.
Thanks,
I wish some where we could find these changes from V9 to V10.
By the way what does BTW stand for and FTWK or some thing like that which a lot of advance members mention on their posts?!
Thanks,
Joseph
By the way, BTW stands for By The Way
And are you thinking of FWIW? For what its worth that stands for For What Its Worth.
Edit: think I should have used the emoticon - post number 666!
Link
Thanks,
Thanks,
Joseph
Me too mate!
Those are just acronyms because we're lazy:
BTW: By The Way
FWIW: For What It's Worth
AFAIK: As Far As I Know
etc.
You can Google any of them for the meanings. Try Googling this - define: RTFM
FTWK - The mind boggles at that one! If you're lucky someone witty like James or Dwight or Andrew may provide an answer to that.
Link.
Chazz
Link wrote:
Right click on it!
Tip of the month!
Thanks Link, this is excellent.
Nattering nabob of negativism
Chazz
Joseph wrote:
By the way what does BTW stand for?
Dwight
By The Way, or BTW: Butthead Thinking Wobbly
See:
http://acronyms.thefreedictionary.com/BTW
Dwight Atkinson
