Strawbale23
Where is the MEP palette
Hello
I have the MEP work environement loaded, and MEP library. And yet I cannot see the MEP palette in the Windows, Palettes Menu
Can anyone help me find the MEP palette please, where is it??
thanks
AC26
https://www.zendsign.fr/
6 Replies 6
c_cignino
Have you try on Windows -> Palettes -> Toolbar?
If you are in MEP enviroment it should load what i think you mean for the "MEP Palette"
Or maybe you're looking for the MEP Layout which is always in Windows -> Palettes
Strawbale23
Hi, this is what I have for my palettes:
AC26
David Maudlin
Strawbale23:
It shows up here (between Load Case Palette and IFC Project Manager). You can add it to your WE, search for Show/Hide MEP Routing.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Strawbale23
Thanks for your reply. I dont have the MEP palette in the Palettes menu. Searching for "Show/Hide MEP Routing" doesnt bring up anything that shows how to make MEP routing palette option appear in the palettes menu.
I really dont understand
AC26
David Maudlin
Strawbale23:
Here is a screen shot of the WE dialog box.
Try setting the middle pane to "All commands by theme". 
Subhabrata
If you can't find the MEP Routing Palette in Archicad, it may be due to changes in how the tool is accessed across different versions. In Archicad 24, the MEP Modeler was integrated into the software, and you can access MEP tools by switching to the "MEP Engineering Profile 24" in the Work Environment settings. In Archicad 27, the traditional MEP Routing Palette was replaced with a new MEP Tool. To use it, go to Design > MEP Modeling > MEP Routing—but if that option isn’t visible, make sure the MEP Work Environment Profile is active by going to Options > Work Environment > Work Environment Profiles, selecting the right profile, and applying it. If MEP commands are still missing, you can manually add them by going to Options > Work Environment > Menus, searching for “MEP Routing” in the Commands list, and dragging it into your menu. If these steps don’t work, it’s a good idea to reach out to Graphisoft support or check their community forum for help.
