Geof Gainer
Where's curtain wall in menu?
I've got a curtain wall selected in section, and try to go to Design>Curtain Wall>Boundary Editing in Section, but have no such menu items.
How do I get there?
AC fan since v 7. Currently on AC 28.1.1 (4100) USA FULL, Apple Silicon,. 2022 Mac Studio, 32G ram. MacOS Sequoia 15.5
7 Replies 7
Erika Epstein
Click on the EDIT IN 3D in the lower right hand corner. That kind of edit is done in that window.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
How do I get there?
You will need to add it to your Work Environment in the Menus section.
Or use one of the default Archicad Work Environments.
Geof Gainer
Yes; I found this seems to work only if the curtain wall was created using the Boundary geometry method though. No biggie to re-do.
Geof Gainer
Tried that, but couldn't find anything more than the Curtain Wall tool itself, plus rotate and label commands.
Try listing "All Commands By Theme".
You want number "19 Curtain Wall".
Geof Gainer
Thanks, Barry. It wouldn't let me move the whole folder, but I just applied the Standard Commands scheme and it shows up fine.
Create a "Curtain Wall" group on the right and then you can select all Curtain Wall commands on the left and move them into that folder (Add selected button) in one step.
