Why do those dots appear above when I select a wall?
LeeJaeYoung
AC27 on window 11
Another option:
1. Select Wall in 3D.
2. Use the "Show Selection" context menu command to display only that Wall in 3D.
3. Activate Door/Window Tool and press CTRL+A (or use "Edit\Select All Doors/Windows" menu command, depending on if it is a Door or Window - or both).
8 REPLIES 8
Andrii Levko
You have some openings above the wall
Andrii
AC 8.1 - 27 INT/POL 3001
Win11 | Ryzen 5600 | 16 GB | GTX 1650
openings or windows are set in higher level.
AC 28 INT 5200/WIN 11
LeeJaeYoung
Thank you
But how do you choose that one?
Neither window nor opening can be selected.
ctrl+F
AC27 on window 11
you can click where the black dots were
Andrii
Zrzut ekranu 2022-07-12 o 19.52.12.pngZrzut ekranu 2022-07-12 o 19.59.13.pngI would also check the state of renovation
Andrii
While you select the wall you will find the black dots appear then while pressing shift make a selection window around those dots then deselect the wall you will discover what those dots are referring to ( I guess windows ) then delete or adjust.
Another option:
Thank you so much
AC27 on window 11
