‎2007-04-11 03:16 AM
(..) ArchiCAD will not be a fully multi-threaded application at any time soon. This is partly because re-writing the ArchiCAD code to support multi-threading is a huge task, and there are areas where it would not cause a dramatic performance increase. Graphisoft will focus on the areas where multi-threading brings the most benefit.thus you don't need octocore (or even quadro) mac pro "at any time soon", because it's a big job for them. (if i think that ac on 8 cores would use 1/8 of the resources available-
Transferring a 32-bit application to 64-bit requires reprogramming even the most basic functions in the software, therefore the change to 64-bit in business softwares will happen at a much slower pace than the rapid change from 32-bit processors to 64-bit processors in the Personal Computer (PC) industry.so mainly they are basing the answer once again on excuse, that it requres recoding ac + on a bad market practise "aww, the other business software developers are also slow on this". sorry, but that doesn't apply to other apps i use, ie, c4d, maxwell. yes, they are a different profile, but- whatever harware resources i give them- it's been effectivelly used. and that's the reason they REALLY are top software solutions. and the argument that archicad has 100x more lines of code can't be an argument.
‎2007-04-17 06:01 AM
Rob wrote:Ha do feat, what ar y talki abo? Whe?
finish half done features and then you can tune and rev up the engine to the latest and trendy binary digit
‎2007-04-17 06:06 AM
‎2007-04-18 10:00 PM
‎2007-04-19 02:48 PM
‎2007-04-20 03:37 AM
‎2007-04-20 05:14 AM
‎2007-04-20 05:43 AM
‎2007-04-20 08:06 AM
‎2007-04-20 04:29 PM
‎2007-04-28 09:32 AM
