What you can do is open the Door/Window Marker for editing.
There you will see the list of parameters. Set them to the desired values and save it as a new Door/window Marker.
Do this with every Favorite style you need.
You will then have these Marker styles available for Doors/Windows. When you want to choose one, just select that Marker and it will default to the parameters you saved it with.
Loving Archicad since 1995 - Find Archicad Tips at x.com/laszlonagy AMD Ryzen9 5900X CPU, 64 GB RAM 3600 MHz, Nvidia GTX 1060 6GB, 500 GB NVMe SSD 2x28" (2560x1440), Windows 10 PRO ENG, Ac20-Ac28
Go to Open Object by Subtype, then navigate to the Window-Door Markers to select the Marker you want to modify.
David Maudlin / Architect www.davidmaudlin.com Digital Architecture AC27 USA • iMac 27" 4.0GHz Quad-core i7 OSX11 | 24 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
Where would I find the 'open by subtype' command? I can get a direct 'open object' dialogue, but the menu displayed in David Maudlin's screen-grab is elusive.
You either need to edit your Work Environment to include this command in the menus or just open the "Edit GDL Library Parts" toolbar (WINDOWS menu > TOOLBARS).
It should be the 6th button along.
One of the forum moderators. Versions 6.5 to 27 i7-10700 @ 2.9Ghz, 32GB ram, GeForce RTX 2060 (6GB), Windows 10 Lenovo Thinkpad - i7-1270P 2.20 GHz, 32GB RAM, Nvidia T550, Windows 11
