Window Schedules
In window schedule can you turn one window off, eg if you draw an aluminium louvre outside using window tool but don't want it to show in schedule
Stress Co_
THIS link may help.
FYI... try the "search" function before you post.... you may find the answer is already there... and add your AC version/Hardware spec.s to your "Signature"
It'll help others answer your platform/version specific questions
Marc Corney, Architect
Red Canoe Architecture, P. A.
WHEW, that was a lot of reading. I don't know if I am more confused now than I was.
on my ArchiCAD 11 on XP, I just select the window or door I don't want to show up on the schedule and go to the Window (or door) Selection Settings dialog box and under the "dimension marker" menu and select "no marker" and then go to the Listing and Labeling menu and erase the ID. I'm not sure if thats a new way for 11 vs. 10...but that's how I do it.
