2016-06-02
09:18 PM
2023-05-26
02:17 PM
Rubia Torres
2016-06-03 07:44 AM
2016-06-03 08:53 AM
2016-06-03 09:02 AM
Erwin wrote:If you do this then you will also have to add the window to the external wall and then an empty opening to match on the internal wall.
If the wall varies in thickness on different levels, you might want to model the interior wall seperate from the outer wall.
2016-06-03 09:09 AM
2016-06-03 03:05 PM
Barry wrote:Thank you Barry (and Erwin). This is a clear explanation of where the problem comes from, and I will find a solution. Your help is very much appreciated.
I am guessing you have separate walls on each storey...
A window can only belong to one wall so can only cut the hole in one wall.
