2024-02-13 10:57 AM
Currently it is possible to place door/window on a wall that is on an uneditable design option. The window/door becomes uneditable after placement so it seem to be a bug or inconsistency.
2024-02-14 03:47 AM
So, when the 'Edit default only' option is on.
Yes, it seems you can add doors and windows still but not edit them or the other elements in that option.
I agree, technically you should not be able to add a door or window as that is editing the wall that you have said to not be editable.
