Window favorites height when inserting favorite
I created a bunch of window favorites with "Header to wall base" set at 6'-8 7/16". These windows all have the same width but their heights vary. When I double click the favorites pallet and insert each individual window AC places them at what seems to be a random "Sill to wall base" height of 4'-4 13/16". The bottom of all these windows lines up instead of them having the header height with which they were saved.
Am I missing something?
Thanks, Doug
James B
Hi Doug,
Make sure you have at least 4022 update.
Under the list of mprovements:
http://www.graphisoft.com/downloads/archicad/updates/AC21/ImprovementsList.html#4022
“229252 EDIT/FAVORITE: Applying a Door/Window Favorite did not apply its Sill Height.”
Therefore, when applying your Favourites, check which is the default Element Transfer Set beng used - next to apply, click the arrow, open the menu, then choose Element Transfer Settings. Select the set with the favourite icon to the right, and check the settings under Window/Door to see if the Sill Height is checked.
James.
James Badcock
Graphisoft Senior Product Manager
Thanks for the reply James.
Sill height was unchecked. It works fine now. Thank you.
Doug
