Window favorites height when inserting favorite
I created a bunch of window favorites with "Header to wall base" set at 6'-8 7/16". These windows all have the same width but their heights vary. When I double click the favorites pallet and insert each individual window AC places them at what seems to be a random "Sill to wall base" height of 4'-4 13/16". The bottom of all these windows lines up instead of them having the header height with which they were saved.
Am I missing something?
Thanks, Doug
James B
Hi Doug,
Make sure you have at least 4022 update.
Under the list of mprovements:
http://www.graphisoft.com/downloads/archicad/updates/AC21/ImprovementsList.html#4022
“229252 EDIT/FAVORITE: Applying a Door/Window Favorite did not apply its Sill Height.”
Therefore, when applying your Favourites, check which is the default Element Transfer Set beng used - next to apply, click the arrow, open the menu, then choose Element Transfer Settings. Select the set with the favourite icon to the right, and check the settings under Window/Door to see if the Sill Height is checked.
James.
James Badcock
Thanks for the reply James.
Sill height was unchecked. It works fine now. Thank you.
Doug
