I've got the window set to "Stud wall with siding." Is this right for a CP wall? Again, it trims up and looks fine in plan, but does not show correctly in section or 3D navigation.
AHHHHHH! Noob mistake. I had originally set the opening lines to the stud, then changed them to the outside of the walls to see if that fixed the problem, and did not store the profile, so it did not change it. I just went to make a new profile and it asked me to store the wall profile, which fixed it.
