‎2023-06-07 07:26 PM
 reveal settings. How do I model this one?
I found splayed reveals but it's always just on one side
‎2023-06-09 05:25 AM
With reveals like that you would have to use a Polygon type wall as the geometry method.
This will allow you to create a segment of wall any shape you want and still be able to place a window in it.
Otherwise create Morph shapes that you can use Solid Element Operations to subtract them from a normal wall (will not show in plan so you will have to add fills).
‎2023-06-09 05:48 AM
Though, you would still need to SEO to get the top and bottom reveal assuming they are the same? Could you instead use a Shell in the shape of your reveal and save it as a Niche?
