2008-06-24
01:21 PM
2023-05-23
03:10 PM
Rubia Torres
2008-06-26 12:53 PM
2008-06-26 02:40 PM
2008-06-26 06:03 PM
2008-06-27 12:13 AM
WALLHOLE 5, 0.1, 0.4457228563283, 1.49683505719, 15, -7.105427357601E-015, 1.56743062233, 15, 0, 0, 15, 0.7096552625813, 0, 15, 0.4457228563283, 1.49683505719, -1 base vert -1.110223024625E-016, 0, 0.1 vert 1.56743062233, -5.551115123126E-017, 0.1 vert -1.110223024625E-016, 0.7096552625813, 0.1 vert -1.110223024625E-016, 0, 0.2 coor 8468, -1, -2, -3, -4 del 1 body -1The original section of the script is:
cprism_ "Glass-Clear", "Glass-Clear", "Glass-Clear", 5, 0.1, 0.4457228563283, 1.49683505719, 15, -7.105427357601E-015, 1.56743062233, 15, 0, 0, 15, 0.7096552625813, 0, 15, 0.4457228563283, 1.49683505719, -1 base vert -1.110223024625E-016, 0, 0.1 vert 1.56743062233, -5.551115123126E-017, 0.1 vert -1.110223024625E-016, 0.7096552625813, 0.1 vert -1.110223024625E-016, 0, 0.2 coor 8468, -1, -2, -3, -4 del 1 body -1
2008-06-27 12:22 AM
EDDY wrote:Thanks, this seems to have done the trick!
Hi Nile,...
Create your slab around your window or door
and set listing & labeling ID set is name : WallHole
Is my picture
Sorry my english
2008-06-27 12:35 AM
WALLHOLE 5, 0.1, 0.4457228563283, 1.49683505719, 15, etc...
2008-06-27 12:40 AM
Peter wrote:Ah now it works cheers!
Nile,
Put the 'WALLHOLE' command on the same line as first parameters.
as in -
