Windows above 1meter...
I am building a window in bathroom... and i want to have it like that:
but it doesnt show up on flor plan...
any sugestions?
Oh, any window above 1meter isnt showing...
5 REPLIES 5
Presumably you have the Floor Plan Cut Plane set to 1m.
so i should change it then? because i never had this problem before...
Just use right settings for the window (FLOOR PLAN DISPLAY)!
if you use projected plan display, you must change Cut Plane height to level >1800.
I have task to show the true wall section and window which is over the Cut line. Then you can use (FLOOR PLAN DISPLAY) - Overhead All.
Best regards
thank you for your help... i made it now
bye
