Windows in profile wall
Hello, I am trying to put a window in a curtain wall, as you can see in the picture. When I put a window, there is a hole on the other side. How this can be fixed?
regards,
Petar
1 REPLY 1
Link
I think you'll need to split your profile in half and create your structure with two walls! It's because it is one wall that it's trying to put the window through both sides. It seems as thought the opening reference doesn't work if you place it on just one side. Interesting - can't say I've seen that before.
Link.
