You can place images in any viewpoint with the Figure Tool or the Drawing Tool if that is what you want.
If you want to use a photo as a background in a photorendering then the image file must be in one of your libraries loaded with the project. Then in the PhotoRendering Settings Dialog you can select that image as a background.
Loving Archicad since 1995 - Find Archicad Tips at x.com/laszlonagy AMD Ryzen9 5900X CPU, 64 GB RAM 3600 MHz, Nvidia GTX 1060 6GB, 500 GB NVMe SSD 2x28" (2560x1440), Windows 10 PRO ENG, Ac20-Ac27
