Working with Complex Shapes
I've created a complex shape within 3DS Max v9, however when I try exporting the shape into AC10 as a gsm, using the 3DSIN add-on, none of its complexity is imported.
Is there a Max add-on (not the 3DSIN), because I believe that trying to import a *.3ds file does not allow the number of faces/vertices when using the 3DSIN add-on.
Many thanks,
Harley
0 Replies 0
