beams disappearing in 3D
i have drawn beams at project zero level. they are showing in plan but not in 3D. if I change the settings to "show on all stories" then it shows. it has something to with project origin which accidentally got changed. even in layout book when i insert a drawing they are at the two extreme corners of the screen. any help will be appreciated.
thanx in advance
Check your "Filter elements in 3d" under
[View] -> [Elements in 3d] menu. Maybe your beams are turned off here?
