Constantin Catana
X, Y, R and A inputs not working in 8.1
X, Y, R and A constraints in 8.1?
I can't use them anymore. Is something changed that I have to know ?
kind regards,
Constantin Catana
Constantin
MG Building Design, Timisoara, Romania
ArchiCAD 8.0 R3, XP SP1
8 Replies 8
They still work as always. Are other keyboard commands working for you?
Check CapsLock status - some shortcuts do not work when CapsLock is on.
Regards,
Piotr Dobrowolski
(':D') These kommands works ONLY in English keyboard mode.
Djordje
Yes ...
CTRL Z, if using non-English keyboard where Z and Y are exchanged, has to be CTRL Y ...
Naaasty.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Constantin Catana
I know that Z and Y are exchanged in Romanian mode. What about A and X ? Not works also ! And Caps Lock is not active !
My previous version was AC 8.0 R3 and this capabilities worked. Few days ago I was uninstalled the old version and installed 8.1 and ... surprise ! This feature no more available.
Usually I clean also the registry files from old version components, before installing a new version. But this time I didn't, I just removed from add/remove programs. In installing process of 8.1 appeared a message window with an error. I had a few choices: "ignore", "cancel", "retry", etc. and with "retry" option, the process continued.
The program starts normal, I can do anything except this important feature. I reinstalled the application (with the same error message !), restarted the computer etc... but nothing.
I will try to reinstall with classic cleaning of the registries. Can be something else ?
regards,
Constantin
Constantin
Constantin Catana
Now I have installed both versions 8.0 R3 and 8.1 on my computer. In the first, works coordinate constrains, in the second NO.
Is something about XP ?
Constantin
Constantin Catana
Djordje wrote:
Naaasty.
Yes it is ! and not Y - Z is the problem ! I described in my previous reply this situation. I just don't know what can I do more !....without Format C:
Constantin
Greg Kmethy
gkmethy wrote:
Hi Constantin,
I was reading through past problems on AC-Talk and discovered that your issue may not have been solved. Any success since?
BTW. Did you try cleaning preferences files?
(they are in: \Documents and Settings\username\Application Data\Graphisoft)
What is the error message you get during installation?
Greg.
Constantin wrote:
Thank you a lot !
It's working now. Maybe it's usefull to make it public on forum.
Regards,
Constantin.
Well, it seems that old trick does it again.
Gergely Kmethy
VP, Customer Success, Graphisoft
