Tincan561
Zone Boundary Black Dots
Can someone explain why black dots appear on some manually placed zones?
They seem to appear when the zone boundaries are colinear with walls.
What are they and how do I turn off this feature?
Thank you.
Archicad 26 Macbook Pro, Ventura 13.6.3
1 Reply 1
Marc H
I work with zones quite a bit, but have not experienced this display.  Black dots are often are associated with invisible, missing, or remote objects or components.  The black dots appear to be outside the zone (purple nodes) and your zone label appears normal.  It could be your zone stamp is an issue, but you would normally see a center node for that.  Perhaps there is another element or object involving itself with the zone?  Alternately, could it be a display issue?
“The best thing about the future is that it comes one day at a time.” - Abraham Lincoln
AC28 USA on 16” 2019 MBP (2.4GHz i9 8-Core, 32GB DDR4, AMD Radeon Pro 5500M 8G GDDR5, 500GB SSD, T3s, Trackpad use) running Tahoe OS + extended w/ (2) 32" ASUS ProArt PAU32C (4K) Monitors
