Zone area text
Johann_P
In some views I would like to display the zone stamp area, in other views I would like to display only the zone name.
If I change the settings of the zone it changes in all views.
How can I apply different settings to different views for the zone stamps?
ArchiCAD24 - since Nov 2020
Revit - 2005 to 2020
Windows 10 Pro
2 screens: nvidia quadro RTX 4000
Johann_P
It seems the information displayed can be controlled to a certain extent.
The "area" can be displayed or not displayed in different scale settings.
But seems that, as per Podolsky's post, not in drawings of the same scale.
Windows 10 Pro
Podolsky
Ace
To solve that I programmed my own zone with MVO control. Standard ArchiCAD zone does not have such a possibility, I'm afraid.
Johann_P
Windows 10 Pro
vdentello
I coded up this guy, so you are able to to set it accordingly to each view through Model View Options.
https://player.vimeo.com/video/460536369
It's in portuguese, but, it could be translated.
Archicad User Since 2013
GDL Developer
Experimenting with API
from Brazil
