Zone label with 0.000
2raarchitecture
All of the labels in projects show these zeros. Thank you for any help!
2RA Building Workshop
www.2rabldgworkshop.com
11th Gen Intel(R) Core(TM) i7-11800H @ 2.30GHz. 16.0 GB. NVIDIA GeForce RTX 3060 Laptop GPU.
ArchiCAD 25. 5002 USA Full
8 REPLIES 8
Lee Hankins
I think that’s a setting in Project Preferences under the File menu. You can set the number of decimals for certain items. You can also set dimension styles that you can save for different views depending on what accuracy of dimensions you require.
Lee Hankins
ArchiCAD 4.5 - Archicad 29
macOS Tahoe (26.0)
DGSketcher
Legend
Is this a legacy project pre AC25? Zones now have independent labels and the previous label data may not be transferring correctly to the new Zone Label.
Depending on the type on information being displayed by the label, it could be Project Preferences > Working Units or Calculation Units.
You will need to adjust the decimal precision.
2raarchitecture
Thank you for your replies. I have been trying working units and calculation units under preferences. That isn't it unless I am missing something.
I tried editing the object itself, and I don't know what else to do...thank you for your feedback.
I ended up duplicating the object and moving it to the Archicad 26 library. The original stamp object was on an embedded library. It worked. Thank you!
2raarchitecture
Opened another teamwork file on the BIMcloud, and the 0.000 returned...
2raarchitecture
When I open the Zone Stamp properties, I am not allowed to choose a different library object...the object is picking it from is in the embedded library. It's not on the ArhiCAD 26 cloud library
Lee Hankins
The Zone Stamp is controlled within the zone categories in attributes.
Lee Hankins
macOS Tahoe (26.0)
