2007-09-19 12:44 PM
2007-09-20 01:03 AM
yukioMishima wrote:to answer some of them . . .
so any help/ insight would be greatly appreciated
Is there a limit on how many new instances of archicad can be launched?not that i've experienced - it will really be determined by the power of your machines.
Is there a way in 11 to easily copy view set details from one archicad file to another? Or is merge still the best way to go about this?view handling is still very much file-specific, so no, you can't easily copy view definitions between files.
dwg in/out:it's always advisable to tweak them to meet your specific needs - dialogue with the consultants you are import/exporting them to/from is essential. and the creation of a template file for each consultant. but that is somewhat of a black-art and could probably be better answered by someone else,
When opening DWG files, is it ok to just use "02 For editable import"? When saving DWG files, is it ok to just use "03 For as is output"? Or do you recommend creating new translators altogether (or just using current ones)?
worksheets:you would not be alone in your confusion! worksheets are currently 2D drafting environments. you may find various uses for them, you may not. one that comes to mind is using them as a place to xref your consultant DWGs - then combined with the trace/reference functionality you can underlay them anywhere in the model for reference.
From reading the ref guide it seems that worksheets are 2D environments. Is this more for non-drawing elements? Not sure how worksheets are supposed to be used. We should still use the detail / section / interior elevation markers for drawings, right?
trace reference:you can't actually 'clear' a reference, but you can change it to from 'off' to any viewpoint/view/layout by right-clicking it in your navigator and choosing 'Show as Trace Reference'...
Once I set a drawing up as a trace reference, archicad remembers it, even if Trace is turned off. Is there a way to remove a trace reference or reset it?
layout book:you are correct - from the VIEW map only! you can drag and drop from anywhere but as you correctly surmised the view holds the various definitions of layers, options, pens, etc... if you make a change to a layer combination it will automatically be reflected in the view and thus the layout too. but if you have created the drawing directly from the project map archicad will have created a new - static - custom view definition. this is Bad Practice.
placing drawings using drag and drop method, does it matter if you drag from the PROJECT map or VIEW map? It was my impression that the view map has the correct saved scale and layers and should be the one to use, but it seems that the project map is the same thing (the files in VIEW map are cloned, could that be the reason the project map has the same settings as the view map?).
I Drawings occupying multiple cells can be set to use the drawing ID at a specified corner, but if you have drawings larger than 1 cell, it doesn’t know to assign consecutive numbers 1, 2, 3... Is there a way around this?kind of. rather than use the grid, you can set them so that the order in which they appear in the layout defines their 'drawing number'. click the little disclosure triangle adjacent to the layout in the layout map and drag the drawings into the order you want. you will need a master that doesn't have a grid.
palette schemes:no! haha! quicklayers is a shocker: it's never been a part of the WE set up. you wouldn't be the first to complain about this either - search the forum here and you will see others. i have actually abandoned the quicklayers palette and made myself a custom quicklayers toolbar. toolbars are remembered in the work environment.
I’ve saved the palette scheme/ work environment to how I like it, but every time I open archicad from scratch, or launch a new instance, the QUICK LAYERS palette never shows up. I’ve tried re-saving the palette scheme, still didn’t work. Is there a bug?
2007-09-20 01:49 AM
project indexes:not to the extent that you (and everybody else!) would like. . .
Is it possible to format the SHEET INDEX so we can use it on the cover sheet? Eg. Add spaces between lines, type in additional MEP sheets, etc.
Can you modify Detail Part Marker_NCS 11 (The tail should be longer, there should be a line between the text and a break in the middle).you can. again, someone else with some GDL knowledge will be better placed to answer this one.
multiple elements (TAB):no. it's nasty. something GS have broken rather than fixed up . . .
I HATE the new way of selecting and modifying elements when there are multiple things at one location!!!!
Am I doing something wrong?
sound effects:in your work environment>user preferences>more options there is an option to enable/disable the sounds.
is there anyway of turning these OFF.... drives me nuts... i know there was a "hack" for doing this in v9... is there someway of doing either within archiCAD itself now... or is there a hack for doing it
2007-09-20 02:34 AM
2007-09-20 10:19 AM
yukioMishima wrote:I find I tend to humbly agree with Ben on almost everything...
dwg in/out:
2007-09-25 03:04 PM
2007-09-25 06:11 PM
yukioMishima wrote:Download the free DWG True View from the Autodesk web site.
- do you know where/ how to get a hold of the standard .shx fonts to help with the translation
2007-09-25 08:41 PM
2007-09-26 09:53 AM
Pen mapping table Autocad Archicad Pen # width mm color color Ustn# Ustn weight # acad1 0.25 red black ustn3 W1 acad2 1.0 yellow black ustn4 W5 acad3 0.35 green black ustn2 W2 acad4 0.18 cyan black ustn7 W0 acad5 1.4 blue black ustn1 W6 acad6 0.7 magenta black ustn5 W4 acad7 0.5 wh/bl black ustn0 W3 acad8 0.13 dark gr black acad9 0.06 grey black acad10 0.0 light gr black
2007-09-28 04:51 PM
yukioMishima wrote:Yes they are. You probably have at least one Intel Mac that can run Windows?
doesn't seem to answer the specific issue of the shx fonts... or are they embedded in the download and we can extract them and use them on a mac?
