align vectorial hatching on a wall?
i have 450 x 225 blockwork coursing as vectorial hatching on some walls, within the facing blockwork material.
can i align the vectorial hatching up or down the wall, as i can with a 3d texture? its just that archicad is showing it with the coursing starting in the wrong place (even though i have created my own fill pattern for it, with the coursing starting at the bottom edge)
i am using archicad 13.
The texture and vector hatching are defined together in the material settings and are both aligned by: Design > Align 3D Texture...
If the texture is aligned and the fill is not you have a problem in the material definition.
ok many thanks
