alignment-drag beam
I need to move the beam from center to the center of a colum, but can not find the mid point of the beam which can drag to the center of a colum,
is there any way similar to Revit auto alignment?
Thanks
1 REPLY 1
If you have your 'Snap Points' turned on and set to 'Half', then when you touch an edge of the beam in section you will get a half snap point.
Now you can drag from there to where ever you want.
You could also use the 'Align' tool (Special align - centre note with draw line arc).
But I don't think this is as good as it is not really intended to be used in this situation.
