angled handrails
hi guys, am trying to angle a handrail onto the top of a small wall,(see screenshop) i have found one in the library that can be angled, but i dont like the style, are there others that are changeable? i have searched the forum and found MEPs but havnt got on my computer.
as usual i am probably missing something very simple.
cheers in advance
using archicad 12
4 Replies 4
Djordje
There are others, in fact most of them are editable.
If you want a different design still, TrussMaker is your friend.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
thanks Djordje, but i have tried them all and can only change the rail length,overhang etc not the angle of the entire object.
could you explain a bit further which ones i can do it with and how. many thanks.
Erika Epstein
In the railing settings boxes
Parameters tab> General Settings> Inclination angle.
Or, as Djordje said, use trussmaker.
Not knowing what style you want, you could also
-make the handrail with a custom profile assigned to a beam which can be sloped and then create your own pickets...
- the pickets can be made with custom profile assigned to columns
-or the curtain wall tool can be used
hmm, so many ways to choose from.
Archicad is a toy, have some fun exploring.
So, what style did you want?
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
thanks erika,
you solved my problem
my fault for trying to do it in the 3d window.
