archicad roof/wall situation
hi, I figured out how to create a complex (curved) roof by drawing a wall profile.
However this also means that I can't trim some of the walls that are intersecting with the "roof" with the trim with roof tool.
Any idea on how to trim another way or how to transform the wall into a roof maybe ?
2 Replies 2
Eduardo Rolon
If you were able to create the roof with a Profile and Wall you should be able to do the same procedure using a Shell and it will behave better. In either case use SEOs with upward extrusion to subtract the "roof" from the walls instead of "trim to roof".
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
Thank you !
