archicad walls
Hi i have a few issues with archicad wall, some i can get to connect with no joint and others show a line, i then have to put it in photoshop before i show the client. can anyone tell me what im doing wrong?
also i spent half my time trying to objects or window, is there an easy way to do this?
Many thanks
3 Replies 3
Hi Paul,
Easy:
Walls join when their Reference Lines connect.
To check that, open the On Screen View Option Palette, and activate the Walls reference lines ( see Pic)
In the example below you will find the two examples.
In case their reference lines are touching, there might be something else, like layers in different priorities.
hope this helps.
Nando Mogollon
Director @ BuilDigital
nando@buildigital.com.au
Using, Archicad Latest AU and INT. Revit Latest (have to keep comparing notes)
More and more... IFC.js, IFCOpenShell
All things Solibri and BIMCollab
hi thanks for your reply, but im non the wiser, could you tell me how to fix it please. many thanks
David Maudlin
paulandrew:
Try adjusting the length of the wall with the bath's door so it is shorter and ends at the sink's wall reference line. Also confirm that the two walls are on the same layer (so they have the same Layer Intersection Group number).
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
