array - a noob question
hi everyone ..i am a very new user of archicad (advanced 3ds max user),i thought i might give it a try in modeling ,the program looks pretty easy & user friendly..
but am stuck now where i want to array windows on a circular wall block..i cant find any option to define a circular angle for an array...is this option available in archicad 9 ?
any help would be much appreciated..
You can array around a curve, use the Multiply command, and select the Rotate radio button. But this won't work with windows. I suggest you array construction lines as you want them, then "Drag a Copy" of your window.
(Drag a Copy works for windows because you can only copy them within the wall, so it follows the curve anyway).
Hope this helps.
(Easy and user friendly? You say that now!)
thanks for the help..that was really helpful..
yeah ..i think so,maybe when considering the learning curve in comparison with 3ds max...but maybe thats just me
