‎2006-02-02 09:35 AM
‎2006-02-08 05:28 PM
‎2006-02-13 05:38 AM
TomWaltz wrote:Strongly supported.
I'm with Ben. I barely ever use the Arrow Tool. I just use its Info Box to control how my selection windows and marquee work.
Once in a while I need some weird polygon selection box and I'll use it, but that's about it.
‎2006-02-13 12:03 PM
‎2006-02-14 04:17 AM
Tom wrote:That is the point. Shift click selects the element whose tool is active, regardless of the number of other overlapping elements. It is two clicks plus shift, instead of cycling.
Using the shift method: Hold down shift, click on shared edge, slab is selected. This is where the problem occurs. I thought that to cycle through available selections you held down shift + ctrl, but it doesn't seem to make a difference, I can't select the wall unless the wall tool is selected in the toolbar...
