assigning different colors to faces of a partition wall
Hello!
How do I assign one color to one face of a partition wall, and another color for another face?
Thank you!
Tim Ball
Set up a material with the surface you want as the colour
Set up a composite or a complex profile using that material
You have a wall with different colour sides
Tim Ball
AC26, iMac
User since V5
Tim Ball
Tim Ball
AC26, iMac
User since V5
DGSketcher
Legend
OR open up the wall setting. Go to the Model settings and Override Surfaces. It depends on your wall modelling and final documentation requirements as to which is easier to use.
Thank you for your answers!
Both work great for me.
