auto brick sill malfunction
I have inserted a window into a complex wall section. After using the wall type parameter "brick veneer wall" the automatic brick sill does not display properly in section. Is there a bug in the tool or have I missed a setting?
Matt
Erika Epstein
Select the window and open its settings box (ctrl/cmdT).
You need to correctly choose the type of wall it is placed in as 'Brick Veneer Wall"
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Again, the wall type is specified as "Brick Veneer Wall". This is what allowed the sloped brick sill to be automatically generated by the window opening. However, the sill does not display properly as you can see in the image of the cut section.
