autocad scale nightmares
I am a new user of AC9 and have done most of my design for this semester with it. I just cant merge the autocad site plan at the scale that I want and there is only one default translator in my student version.....please hepl
2 Replies 2
If you "create new translator" you can alter settings (such as scale) yourself by selecting the appropriate options, then save your new translator settings for future use.
Aaron Bourgoin
the new translator is created by highlighting the existing translator and creating a duplicate just as Stuart says.
Trial and error is still likely to be involved - first get the input units right. Site stuff is probably meters. This is done inside the translator settings. Set it to something and then open the file. Ignore the size of the text for the moment and just get something on screen that you can measure.
Once you are assured that the input scale is right you will also have to then set the scale in the 2D window to something useful - if 1/8" to the foot is the default, you won't want that. Try setting it to 1:200 or greater (or imperial equivalent). This will adjust the text size to something that makes sense.
This last part is in response to the question the translator asks about the scale you want to display it in. I've never once got what I wanted the first time, but I do it too infrequently to have a standrad in place. Shame on me.
Glad to see someone at DalTech (TUNS is my former home) using ArchiCAD. Don't be a guest on the forum. Sign up Today!
Think Like a Spec Writer
MacBook M4Pro - 24Gb RAM
AC4.55 through 29 / AC29.2.1 USA
Rhino 8.34 Mac
MacOS Tahoe 26.5.2
