background pen of a wall does not shange - AGAIN....
Hi!
My background pen is always transparent no mather wich color I set.
I am using Archicad 9 and have tried to find the feature (all transparent, or something like that) in Preferences/miscellaneous, but can not find it. I have also tried to change the use elements background pen in wall options window.
Thanx in advance...
Jaros
Check that your display options are correct. Should be set to use object's settings.
Hi Millard!
Thank you for the tip. I have never noticed this feature in Options. Is it new in 9.0?
Jaros
jaros wrote:
Hi Millard!
Jaros
No, this feature was earlier found under Options/Preferences/Miscellaneous dialogue box.
Maybe that's why you don't recognize it?
