background pen of a wall does not shange - AGAIN....
Hi!
My background pen is always transparent no mather wich color I set.
I am using Archicad 9 and have tried to find the feature (all transparent, or something like that) in Preferences/miscellaneous, but can not find it. I have also tried to change the use elements background pen in wall options window.
Thanx in advance...
Jaros
3 Replies 3
Check that your display options are correct. Should be set to use object's settings.
Hi Millard!
Thank you for the tip. I have never noticed this feature in Options. Is it new in 9.0?
Jaros
jaros wrote:
Hi Millard!
Jaros
No, this feature was earlier found under Options/Preferences/Miscellaneous dialogue box.
Maybe that's why you don't recognize it?
