We value your input!
building materials cutfills
pelly
hi, i would like to know how to create cut fills for concretes like in the attached photo
4 REPLIES 4
Hi @pelly , you can chose the element ( wall or column ) and open Building Materials dialogue either from options menu - Element Attributes - Building Materials or from Attributes Toolbar then Duplicate building material from New button and from Structure and appearance panel change two parameters as you wishCut Fill Foreground Pen & Cut Fill Background Pen.
AC 28 INT 3001/WIN 11
thanks man.
I thought there was a hollow core slab tool or object somewhere??
Eric Milberger, Architect | Master Planner
You can use opening tool to achieve this voids in hollow core slab, I hope it can be done.
