KURTLIN
can i do complex in elevation?
hi, i want to build a ㄇ with trapezoid shape section
this shape can easily be done using wall element
the problem is wall can only be draw in plan but not elevation
i did try to build it separately with column and beam
but wants know is it possible to build this shape in elevation as easy as in plan
1 Solution
Try the Curtain Wall tool with the "Boundary" Geometry Method.
You can draw the boundary in Elevation.
You can make the Scheme to be an empty pattern - click the X button in the upper right corner to remove the scheme.
Then, in the Elevation, select the Curtain Wall and enter Edit Mode. Make the bottom Frame invisible. For the other three Frames, choose the "Profiled Butt-Glazed Frame" type, which will let you select a Profile for the Frames.
Go to post
2 Replies 2
KURTLIN
it work! thanks
