We value your input!
can't save in u3d it's appear "system out of memory"
i don't know how to do . I need to save 3d pdf .
4 REPLIES 4
It might be that your model is too large. U3D seems only good for small vignettes.
How can i do if i need to make 3dpdf with large file?
It may not be possible. I don't know the where the limit is, but I have had no trouble with very small files, no luck with very large ones, and no experience with anything in between.
Djordje
Do the Polycount, check the number of polygons in the model.
Try setting all your windows and doors to scale sensitive, hide all the layers that you actually don't see, remove doorknobs etc, simple 3D for the trees ....
Then, set your 3D view to a 1:500 or 1:1000 scale.
Do the Polycount again. If the number is significantly down, you are making progress! The Polycount will list all the used library parts, maybe you can make them even less complex. Check the parameters.
And so on ...
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
