change story hieght but do not move elements?
Is there a way to change the height of stories without moving the 3d parts assigned to that story?
4 Replies 4
Djordje
No.
Whatever is on a storey keeps its relation to it.
If you move storeys, you will have to move the dependent elements manually.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Djordje wrote:
No.
yes , its as Djordje said if its connected it is connected ,
but i don't know if that helps , but you can transfer those objects to other level change the level hight then get it connected again to the original level .
ok the steps to do that ( if it is helpful to you )
- go to 3D window , isolate the elements you want to do this with , settings , change the relative base hight to ( to user origin ) instead of ( Home story). then change the home story of these elements , to another level that you are not going to change . ( we connected that to user origin to be sure that the Z value will not be changed when we connected it to another level )
- Change the Story level you want .
- so now those elements are at the same Z value , the story is changed , but they are not connected to that story , and will not appear there . so now your task is to repeat the same thing and connect those elements back to original story so it will be displayed there .
if you are interested , give it a try .
ok I thought so, seems like a major flaw in the software...Yes I know ArchiCAd is all about good organization from the start of a project but elevations can change
jespizua
Full agree, would be very useful have that ability.
osx 10.14 | archicad 22 | cinema4d 18 |
