changing wall type to show brick wainscott and siding above
Is there a way to create a new wall type that has brick wainscott from 0 to 3' above finish floor line, and siding above that? or am I constrained to one wall type for the entire wall?
thanks!
3 Replies 3
Investigate Complex Profile walls, plenty of threads on the forum (use the search button just below the banner on this page) or the Help files.
Srinivas
Read this tutorial from Eric on how you can creatively use Complex Profiles
http://www.aecbytes.com/tipsandtricks/2008/issue32-archicad.html
it should through enough light on how you can achieve brick wainscott and mouldings for your walls.
www.bimvizstudio.com
ArchiCAD Service
ArchiCAD since v9 to latest
Mac, Windows 11
Stephen Dolbee
I use 2 separate walls.
AC19(9001), 27" iMac i7, 12 gb ram, ATI Radeon HD 4850 512mb, OS 10.12.6
