4hotshoes
I am confused on how to change the surface color of a profile
I have a client who wants to see color options for trim. It would make sense to me to have a single place to change the color of all siding, all fascia, all window trim, all corner trim, ... It I set it up right. However, I am confused about the best way to do that with a profile. I have several hundreds of one profile in the model and twenty or so of another profile in the model. And it seems that a profile's surface color can be controlled in several places and I can't seem to find them all. Where is the best place to globally change them all in a single location without having to select all of them.
For example: I have a house with board and batten siding with corner trim and frieze trim under the eave. I want all to be the same color and the ability to change the color of all in one place. The battens and corners are profiles while the siding is a wall. Then there is the window trim, which I forgot to mention.
Changing all the walls is easy as I select the building material and select a new color.
Any thoughts?
Todd Oeftger
AC27 Mac MacBook Pro 15", 2019, 2.3 GHz i9, 32GB, Radeon Pro 560X 4GB, 500GB SSD, 32" Samsung Display (2560x1440)
Lingwisyer
Guru
If your profiles only use a single colour, you could set up a Graphic Override to change that single colour to a second desired one depending on your option.
Ling,
Have you tried the surface painter tool in 3D?
