cheap trick roof and slab intersection
Slabs/floors that intersect a roof can generate a little triangle in section/elevation views. My cheap trick is to fill in the pesky triangle with a couple small chunks of slab, each one a little shorter than it's neighbor. I stick them on a layer like "roofs" which is hidden except for when I am doing 3D modeling. Maybe some day slabs will trim to roofs at an angle
bill (pleased with self) roslansky
2 Replies 2
TomWaltz
They already do if you use Solid Element Operations.
Tom Waltz
Solid Element Operations (SEO) is the solution, but using a Solid (White) Fill with a white Outline is a better solution than creating many little slabs. Bring this 2D object to the Front. I do not use patches (are they still used), but if SEO is not an option than using patch might be a solution in some cases.
