‎2011-09-0605:03 PM - last edited on ‎2023-05-2401:05 PM by Rubia Torres
‎2011-09-0605:03 PM
transfer of walls from 14-15 all is just white in 3d window. My doors and base and crown should be gloss white and walls should have a color.
Is there some new setting buried somewhere?
Did you just open the 14 file in 15?
If so the materials (colours) should be as they were in 14.
If you copied & pasted the walls then the material attributes are probably different in the 2 files.
What method did you use?
One of the forum moderators. Versions 6.5 to 27 i7-10700 @ 2.9Ghz, 32GB ram, GeForce RTX 2060 (6GB), Windows 10 Lenovo Thinkpad - i7-1270P 2.20 GHz, 32GB RAM, Nvidia T550, Windows 11
