ā2006-06-21 07:11 AM
ā2006-06-21 09:33 AM
ā2006-06-21 11:45 AM
ā2006-06-21 12:10 PM
One problematic issue with the complex profiles (I have only played with the walls) is that if a profile is edited, all placed instances revert to the height of the profile as drawn in the profile editor and walls do not keep a different height that might have been given when it was placed in the model.This sounds alarming Mike, but I'm not sure I'm grasping the problem. It seems like more of a feature to me.
ā2006-06-21 01:24 PM
ā2006-06-21 03:52 PM
TomWaltz wrote:I think it's clear that this would be the desirable behavior (with an
I would have thought the amount of wall "stretch" would be a parameter that is set for each instance of the wall and be maintained even after you edit the profile. That does not seem to be the case.
ā2006-06-23 04:12 PM
TomWaltz wrote:This certainly would be the desired function. It seems that if a stretchable area has been defined in the profile, a previously placed wall using that profile should maintain a manually set dimension. If a user goes to the effort to set a height of a wall, usually that has some significance that wants to be maintained. I can certainly see the advantage of having a profile change for many "non wall" elements that use the profile wall as a mean to model.
ā2006-06-24 01:56 AM
TomWaltz wrote:this isn't just the desirable behaviour, this is essential. another over-looked or poorly thought out, (or both) usability stuff-up.
ā2006-06-25 01:22 AM
Mike wrote:Big time!
I would call this a bug...
